Why is the Exterior wall not sitting on the floor beams ?
MarkDi
I think the problem is the CA (X13) is showing only the rain screen studding not the main wall studs
Removing the rain screen then no external wall studding is displayed, internal wall studding is display OK
However creating a new external wall type, the problem is solved,
Had odd problems like this before, it appears that making changes does not always change everything and CA has some hidden settings
