MarkDi Posted February 8, 2023 Share Posted February 8, 2023 The outside wall appears to float, I would have expected the outside to sit on the flooring beams I expect there is an option to line these up, Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 8, 2023 Share Posted February 8, 2023 you might want to post the plan. Does a cross section show the same? Did you rebuild the framing? Link to comment Share on other sites More sharing options...
MarkDi Posted February 8, 2023 Author Share Posted February 8, 2023 I think the problem is the CA (X13) is showing only the rain screen studding not the main wall studs Removing the rain screen then no external wall studding is displayed, internal wall studding is display OK However creating a new external wall type, the problem is solved, Had odd problems like this before, it appears that making changes does not always change everything and CA has some hidden settings Link to comment Share on other sites More sharing options...
