Storyline modification
develospec9
Hi, I’m having a very annoying problem with the storyline dimensions in elevation view. I simply want to remove certain Extension/markers .. I saw CA videos that show just to pull the end of the line towards the marker but that is not working … anybody know how to do this ?
using x10
thank you !
Hi Glenn! Thank you very much !!  That worked very easily following your directions. I was literally trying to figure this out for about 3 months lol. I tried everything, changing storyline defaults , changing specifications in dialog box , pulling lines in every direction , you name it … I noticed it worked sometimes and other times it just moved the line .. but now I know to select the market first and then pull the diamond off .
seems like it should have been easier , or just more obvious I guess . Thank you !
