RobUSMC Posted January 22, 2023 Share Posted January 22, 2023 Im adding an addition to the side of an existing home that has 2 x 4 wall framing with siding that has a single pour monolithic slab on grade. The new addition foundation will be the exact same so there will be a new footer next to the existing and doweled together. Does anyone have a CAD cross section showing this? I was surprised not to find that configuration in the library. Thanks Link to comment Share on other sites More sharing options...
RobUSMC Posted January 22, 2023 Author Share Posted January 22, 2023 Thanks. I was looking for a detailed cross section with dowels, J bolts and all the rebar tie ins. Im trying to use one from the library and edit it. Again thank you Link to comment Share on other sites More sharing options...
builtright3 Posted January 22, 2023 Share Posted January 22, 2023 1 hour ago, RobUSMC said: Thanks. I was looking for a detailed cross section with dowels, J bolts and all the rebar tie ins. Im trying to use one from the library and edit it. Again thank you I dont have one drawn in cad but you can draw it pretty easy 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted January 22, 2023 Author Share Posted January 22, 2023 Thanks Link to comment Share on other sites More sharing options...
