bringing in a house as a symbol
Douglas49
I'm designing a couple of houses on the same site. I've brought in the second house as a symbol and placed in position.
In the 3D perspective view both buildings are showing.
However, in the cross section/ elevation views, the symbol house is not appearing.
I've gone looking for the layer it is on to turn that layer on, however there appears to be no layers for symbols under 'symbols' .
Bit stuck on this, can't spot what I'm missing here?
Symbols have plenty of category choices when they are created so those have default layers but a symbol can be moved to any layer so it is best to select it and open the DBX and check or have ALDO open when you select it and it will identify the layer for you and it can be turned on or off.   I assume the symbol is just for background orientation and not actually using it for section views.
