Rotating plan, then changes x,y axis to match
Heather_Anderson
To rotate objects for reuse in another plan, either group select or use one of the Edit Area tools.  The latter group of tools are far more robust and do things a simple group select cannot.
The Rotate Plan View tool is the wrong tool for the job and essentially just rotates the drawing board.  Although there are a couple other good uses, I typically only use that tool for temporarily reorienting myself for off angle work and for Plot Plans.
