Accuracy of Materials List?
VWCALBUG
Hello,
I have designed a 2988sqft house with what I believe is all fairly accurate build of the walls and floors. When I run the materials list, it shows 698 feet of "base moulding". I assume this is the baseboard, right? This seems low. I don't see another category for base moulding, there is "interior casing" at 1140 ft, that's starting to sound more reasonable.
When I click "find object in plan" to see what it's referring to, it goes to the plan, but I don't see anything highlighted or indicated, not sure what to look for when it switches me to the plan?
Thanks,
Justin
Certainly should be, "Find in Plan" should take you back to the plan with the object(s) selected - it may seem like nothing is selected because, well everything is selected. One way to test this is to open a room, go to moldings, uncheck Use Default and delete it, then remake a Mat List. The length should drop and Find In Plan should highlight all but that room.
This is a kind of tough one to manually verify in HD but it's simply tracing the perimeter of each room (that has Default Casing).
That's specifically all door/window casing.
If it makes you feel any better, I've never seen the MatList get anything blatantly wrong, if anything there are some rounding flukes here n there, but it's just measuring all the things it sees in the plan.
