Wall Definition - Copy / Paste Material
JKEdmo
Quick question -
I wanted to know if there is a way to bring over a whole layer definition from an existing wall when I am building a new wall type?
For example, if I want my "lap siding" from another wall -- complete with pattern, texture, fill and thickness -- can I say copy/paste it into the new wall type?
The reason I ask is Autocad Architecture (my basis of reference) allows this and I was hoping Chief does too.  It is a bit of a time saver.
Thanks again,
Jim
You could open wall type definition and copy the wall there. If you've changed pattern, texture, fill etc on the layer its best to save that material definition under a new name when you create it. For example cream siding > in plan materials > copy edit and rename new...hope that makes sense
4 minutes ago, richoffan said:
692946064_Screenshot2022-12-302113281.thumb.jpg.27cf6d2895cbf2aed1e8e1a6185f6382.jpg1765307676_Screenshot2022-12-302114392.thumb.jpg.c675f97d4d98df50352d0348a9b45e19.jpg
Rich,  I think that's what I already do.  But, I found I needed to manually input some of the new materials from my wall in order to exactly match same materials in existing walls.
Jim
5 minutes ago, solver said:
Nope.
See the buttons at the top of the wall definition dialog. Often quickest to copy the wall and then make changes.
You can also simply select a new material but the fill will not automatically populate.
That's what I figured.  Do you think this a feature people want, or is it easy enough to just deal with it?
Jim
