5Design Posted December 9, 2022 Share Posted December 9, 2022 I haven't changed any settings/defaults but when I change the floor height in one room (box window) it changes all of them. It's never done that before. I've toggled all options. I checked the last plan I did with a boxed window and the settings are the same. Anyone use another program that doesn't think it's God? Just let me control each input. I don't need you to automatically change other values because I change one. Rant over. Link to drive file:https://drive.google.com/file/d/1-N28PEhE4d12oyP7NsjZAI9NphtvKssZ/view?usp=sharing Thanks, Link to comment Share on other sites More sharing options...
SNestor Posted December 9, 2022 Share Posted December 9, 2022 Which bay window is giving you a problem...there are a few in the plan Link to comment Share on other sites More sharing options...
5Design Posted December 9, 2022 Author Share Posted December 9, 2022 Just now, SNestor said: Which bay window is giving you a problem...there are a few in the plan I've only tried the front left (4), but they all need to be changed. Number 3 goes to the ground but that whole thing is going away. Number 1 is the box feature in Chief, which is great if you only have one window. Link to comment Share on other sites More sharing options...
SNestor Posted December 9, 2022 Share Posted December 9, 2022 OK...so, what are you attempting to do with #1 bay window? Are you trying to raise the floor? If so, how high. Link to comment Share on other sites More sharing options...
5Design Posted December 9, 2022 Author Share Posted December 9, 2022 1 minute ago, SNestor said: OK...so, what are you attempting to do with #1 bay window? Are you trying to raise the floor? If so, how high. #1 is fine. #s 2,4, & 5 are 24' AFF and the CLG is at 74" AFF. Link to comment Share on other sites More sharing options...
SNestor Posted December 9, 2022 Share Posted December 9, 2022 I modified bay window #4. Take a look at what I did. The brickledge created by the wall type is still not perfect...but, you will see how I got the floor etc put together. 7300 Overland Trail Proposed - Edited.plan.zip Link to comment Share on other sites More sharing options...
5Design Posted December 9, 2022 Author Share Posted December 9, 2022 11 minutes ago, SNestor said: I modified bay window #4. Take a look at what I did. The brickledge created by the wall type is still not perfect...but, you will see how I got the floor etc put together. 7300 Overland Trail Proposed - Edited.plan.zip 3.76 MB · 0 downloads Well, what's your secret? When I change the settings for the other window it goes berserk and changes the rest of the house to the same (on the one you sent back). Still shows the foundation. Is there a default setting that applies one room structure to all? Link to comment Share on other sites More sharing options...
5Design Posted December 9, 2022 Author Share Posted December 9, 2022 13 minutes ago, 5Design said: Well, what's your secret? When I change the settings for the other window it goes berserk and changes the rest of the house to the same (on the one you sent back). Still shows the foundation. Is there a default setting that applies one room structure to all? Managed to get it close to accurate by deleting the foundation walls under it. But how does this make sense? Ahh, the joys of Chief. Thanks for your help! Link to comment Share on other sites More sharing options...
SNestor Posted December 10, 2022 Share Posted December 10, 2022 I made a video that might help... How To: Raised Floor in a Bay Window with mono-slabs - Watch Video 4 Link to comment Share on other sites More sharing options...
5Design Posted December 10, 2022 Author Share Posted December 10, 2022 12 hours ago, SNestor said: I made a video that might help... How To: Raised Floor in a Bay Window with mono-slabs - Watch Video That's greatness, Steve. Thanks! I had forgotten about the doorway trick. 1 Link to comment Share on other sites More sharing options...
