RJRDesign Posted November 29, 2022 Share Posted November 29, 2022 The tutorial shows to click New Layout, but there is not such icon in the print dialog. Chief Arch Pro Im trying to show title, Sheet # etc. as found on standard drawings for submittal, Link to comment Share on other sites More sharing options...
Kbird1 Posted November 29, 2022 Share Posted November 29, 2022 44 minutes ago, RJRDesign said: The tutorial shows to click New Layout, but there is not such icon in the print dialog. Chief Arch Pro Im trying to show title, Sheet # etc. as found on standard drawings for submittal, It sounds like you may need to be over on HomeTalk as it sounds like you have Home Designer Pro ($600), not Chief Architect Premier ($3000) ? https://hometalk.chiefarchitect.com/ also good to do for both forums is: https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 But the New Layout Option , should be seen in File > New Layout , while in PLAN VIEW, which will open a new Layout file , which you need to SEND the Plan views too. https://www.homedesignersoftware.com/support/article/KB-00527/creating-a-layout-in-home-designer-pro.html Mick. Link to comment Share on other sites More sharing options...
