Unwanted Footings Under my Exterior Walls?
CovOps
Go to solution Solved by rgardner,
  • Solution
21 minutes ago, CovOps said:
I've no idea where these "footings" are coming from. They show up even though I've got a foundation underneath - never seen this before. Any ideas?
Looks like your first floor exterior walls are set as a foundation wall set to build footings below in your structure panel of the wall dbx.
9 hours ago, CovOps said:
Thanks rgardner - a very simple solution!
Glad that solved your issue.  To help others who are searching for the same issue it is common to mark the answer that was correct as solving your issue so when someone has the same problem and the future does a search they can find the answer quickly.
