Roof will not generate
pswiseman
17 minutes ago, pswiseman said:
I am trying to put a shed roof on the bump out seen in the photo.  I have already edited the other roof plans and do not want them to change.
If you turned off Auto Rebuild Roofs, it won't automatically generate.
Is there an easy way to do this?
Yes, very easy to draw a manual roof plane there using Premier. I'm not sure if Interiors has that tool, I use Premier.
