Cadman_97701 Posted October 25, 2022 Share Posted October 25, 2022 Hello..... I'm working on adding a Covered Entry to an existing residence. I've got to 2 main roof lines where I want them. Now I need to find out how to draw a Cricket (shown in red) on the attached file. Thanks for any help!! Link to comment Share on other sites More sharing options...
GeneDavis Posted October 25, 2022 Share Posted October 25, 2022 That's not its shape. From that peak's rear end the "ridge" of the cricket will be a level line across the upper roof over to the valley line. Manually draw a roof plane at that valley bottom, its baseline parallel to the work line you drew across the top, drag it up to that top, edit its pitch to have it ridge height match the canopy ridge, the edit in 2D plan to the triangular shape needed. Its fascia height should already be the valley bottom point where you started to draw the plane. Show us the result. Link to comment Share on other sites More sharing options...
Cadman_97701 Posted October 25, 2022 Author Share Posted October 25, 2022 Yes, that worked very well. Thanks for the help!! Link to comment Share on other sites More sharing options...
