Basement only correct on one room
dnh234589
When I create foundation, region "A" in attached image always forms with floor joists and seems to be responsive to changes in Build Foundation dialog. For example in region A, I can hang the joists, or not, and the joist parameters will adjust each time I rebuild the 1st floor floor.
However Region "B" in attached image doesn't seem to ever form the basement ceiling / 1st floor floor correctly.
Above Region A there is a room. I've tried combing through the Room Specifications of that room, and of each of its walls, to find out what is different about that room -- but I don't see anything different. If I delete that room by removing one of the walls, region A goes away and it is all the undesirable Region B.
In the end I just want regions A and B to be one big merged region (I don't want the foundation walls around A, but it puts them there automatically), and for that big region to be spanned by regular floor joists.
232x Driveway house (2).zip
