Add trailing text to dimension defaults
AvoyeDesign
Say you want a dimension default for a task you do repeatedly where a dimension requires the same exact trailing text.
Go into Preferences>Units.  Create a custom unit as follows:  [unit] [trailing text]
Where Unit is the actual unit of measure you want displayed ( '  "  '-"  m  mm) and Trailing Text is the common text you would use in this application.
This only works for trailing text as units only trail dimensions, not lead them.
