Roof Cuts Into Room Without Closing Wall Above
Gelby4
5 hours ago, Gelby4 said:
Yep, that's the method I got to work but only with an interior wall. If I do the same steps with an exterior wall, it doesn't cut below for some reason
I too struggled with walls and roofs where they needed to cut etc. when I first started using Chief.  What Scott (a famous forum helper back in the day) pounded into me is how precise Chief needs the connections to be.  I'll admit Chief has made it easier with some automated function, but overall the method you use to connect walls/roofs needs to be done a very particular way.  See how in Eric's example the roof plane jogs under the wall in just the right spot?
Nowadays I don't even have to think about it very often and it works great in most situations.
