bobditch Posted January 19, 2015 Share Posted January 19, 2015 I can't figure out how to change the porch roof height. I'd like to drop it 10" and nothing in "Room Specification > Structure" does the trick. Thanks, Bob Link to comment Share on other sites More sharing options...
Solution MikeJG Posted January 19, 2015 Solution Share Posted January 19, 2015 You may need to rebuild your roofs if you dropped the ceiling height in the room spec./structure tab and nothing happened. If you manually drew the roof planes, and just want them 10" lower, you can open both roof planes, lock the pitch and subtract 10" from the baseline, fascia top, or ridge numbers. Another thing you can do is select the roof planes then use the "Transform/Replicate Object' tool on the bottom toolbar and putting -10 in the Z Delta box. Hope that helps. Link to comment Share on other sites More sharing options...
bobditch Posted January 20, 2015 Author Share Posted January 20, 2015 That did it ... Thanks Mike Link to comment Share on other sites More sharing options...
