JasonJFBdesign Posted June 27, 2022 Share Posted June 27, 2022 Hi All, I've recently upgraded to X14. I'd been working on a project and have now continued with X14. I had dimensioned the project in X13. when it was opened in x14 the last dimension line is sitting over the previous dimension line underneath. I've attempted to move with the red square grab handles but it won't shift. some of the dimension lines around the project will let you and others won't. any ideas as to why I can't move some of my dimension lines? Link to comment Share on other sites More sharing options...
glennw Posted June 27, 2022 Share Posted June 27, 2022 Hi Jason, My best guess is that you have Fixed Proximity checked for those stubborn dimensions. You can change it here in the Fixed Prox column on a dimension by dimension basis: Or here as the default - I would normally have it off in the defaults: 1 Link to comment Share on other sites More sharing options...
