1/4" Scale Dimension Defaults
SamPWB
35 minutes ago, SamPWB said:
Total newbie question. I'm following the "Designing a Traditional Pole Barn Structure" (https://www.chiefarchitect.com/support/article/KB-01069/designing-a-traditional-pole-barn-structure.html#defaults) and it calls modify the 1/4" Scale Dimension Defaults. Maybe a simple fix but I don't have a 1/4" Scale Dimension Default...
Thanks!
It was name changed in recent Versions, to the one highlighted, CA defaults this to 6" high but 4.5" is closer to a true 1/4" scale height.
you need to be aware what version the Video was made in sometimes and the other end of that is doing yur Forum Signature so other know what version you are using before they answer as sometime answers are Version specific.
