Show Schedule Callout
Steve_Nyhof
Hello,
How can I globally turn off the Show Schedule Callout? As I insert Library objects I can open the object and turn if off, but if my object is a block I need to explode the block and then select the object with the call out on.
Thank you,
Steve
24 minutes ago, rgardner said:
So are you looking for a way to do it other than with the Defaults, or turning the layer off?  What is your end desired results?
Well, now that you said layer, I may find that it is as easy as turning a layer off. The symbols just started to show up when I started to use X14
