Jaymon Posted May 29, 2022 Share Posted May 29, 2022 Hi, I am having issue with 2D polyline fill showing odd lines in it. more noticeable once printing to PDF. it only for basic As Cons where i don't need to draw it in 3D and working with others DWG files so all just modified in 2D. if anyone could help if there is a setting i need to change? Thanks Height Safety Plan Layout.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted May 29, 2022 Share Posted May 29, 2022 I have not seen an issue that displays quite like that before. You would need to let us know what version you are producing the PDF with and likely post the plan file to be sure there are no artifacts in the plan that might be causing the problem. Are these the irregularities you are referring to ? Link to comment Share on other sites More sharing options...
Jaymon Posted May 29, 2022 Author Share Posted May 29, 2022 Thanks Eric & Chopsaw, I will try and add in a screenshot and the file. this was only meant to be a quick conversion of some existing drawings to As Cons for a project. Any help would be appreciated. Thanks Height Safety Plan Layout.layout HEIGHT SAFETY SYSTEM.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted May 29, 2022 Share Posted May 29, 2022 It seems to be a known issue that I have sent in but not enough others have sent in yet. So I would encourage you to do that and send it in. For now if there is a way you can control the layering such that you don't need to use a background fill with the hatch pattern you should be fine to print to PDF. Also some PDF viewers do not have as much of an issue with this as others so try that if it is an option. Link to comment Share on other sites More sharing options...
