Cabinets and desk
CharityS
two ways to do that. (Not am using a framed cabinet, if you want frameless set the separation to 3/4")
1- make a cabinet that is just a drawer with no toe kick and set the top height to match the other cabinets.-easiest to make and to change drawer height, reads properly in a cabinet schedule.
2-make cabinet with no toe kick, change front left and right separation to 0", change door section to an opening with no shelves. Set drawer height to suit.
2a-Split Drawer vertically, move the separation to the left, change the right drawer to a separation and set width to default (click the wrench)
2b- go to left, match front, then changed that to custom face and set the drawer to be a blank area...repeat for back and other side.
Method 2 has the advantage of being easier to move, but disadvantages are much harder to make, harder to change drawer height, shows incorrectly in a cabinet schedule and more work. That said it might be worth doing this once for the sake of learning :) Plan with both in it attached.
Desks.zip
  • Upvote 2
