MacChief Posted May 1, 2022 Share Posted May 1, 2022 This may be a little OCD... I cannot seem to get the line coordinates to match the parcel map. Got close but would like to understand how best to deal with these types of parcels. See attached file. Thanks! -Chris Chief X13 iMac 27" 5K MacOS 12.3.1 MacChief - Plot Test.zip Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted May 1, 2022 Solution Share Posted May 1, 2022 What would be nice is if surveyors were a little more OCD... Between the survey not quite closing and Chief's defaults it gets a little tricky to make it work the way the survey is drawn but that is the point if someone has an issue with your interpretation they will request the original survey so it had better match. If this is what you are after shoot me a PM and I will try to explain. Link to comment Share on other sites More sharing options...
MacChief Posted May 1, 2022 Author Share Posted May 1, 2022 Yes, exactly. Thanks for the support. Link to comment Share on other sites More sharing options...
