RAHarris Posted April 19, 2022 Share Posted April 19, 2022 Hello, How do you resize your tile size? I have went into scale and put 12" x 24" but it doesnt show up that way in my 3d or 2d. Thank you. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 19, 2022 Share Posted April 19, 2022 1 hour ago, RAHarris said: Hello, How do you resize your tile size? I have went into scale and put 12" x 24" but it doesnt show up that way in my 3d or 2d. Thank you. tile is one of the trickier things to change, you can't easily change grout colors for example. Tip: 2D uses Patterns 3D uses Textures ( pics ) A good place to start if you have Questions is the Knowledgebase ( KB) which has many mini-tutorials , you can even download a PDF if you want too. for example : https://www.chiefarchitect.com/support/article/KB-01006/customizing-a-library-material.html https://www.chiefarchitect.com/support/article/KB-01124/message-the-material-appears-to-have-an-incorrect-pattern.html https://www.chiefarchitect.com/support/article/KB-00767/creating-a-new-material.html there is also a Video https://www.chiefarchitect.com/videos/watch/10145/creating-custom-tile-materials.html?playlist=170 M. 1 Link to comment Share on other sites More sharing options...
