Partition Wall - In the Wall Type Definition
Joe_Carrick
This rather obscure setting prevents the wall from obscuring the surfaces of abutting floors, ceilings and walls.  This is important especially for 3D Views - since otherwise you might be seeing a wall or floor that doesn't have a surface material at the intersection (half walls, railing walls, etc.)
Instead of using a PSolid to cover such conditions it's usually possible to eliminate the problem just by specifying the Wall Type as a "Partition".  Personally, I think this setting should be more a general setting than a "Wall Type" setting.
  • Upvote 3
