Framing Won't Extend Up to Vaulted Ceiling
DavidInMaine
Hi, I have an interior wall with a transom window.  In 3D view the wall appears to extend up to the vaulted ceiling correctly.  In framing view the wall stops midway up the window instead of showing framing up to the ceiling.  It is a bathroom that for awhile I had checked "Flat Ceiling Over This Room" (intended for the interior bathroom ceiling only) but unchecked it to try and show framing up to ceiling which isn't working.
David
Premier x13
Mac
23 minutes ago, solver said:
Do you have Auto Rebuild wall framing on, or have you rebuilt framing for that wall?
Have you tried selecting Balloon Through Ceiling Above?
Balloon Through Ceiling Above did not work (a section of framing extended down into the window).
But turning on Auto Rebuild Wall Framing with help from this link did the trick: https://www.chiefarchitect.com/support/article/KB-00335/troubleshooting-wall-framing-issues.html
Thanks for your prompt replies.
