DavidInMaine Posted April 10, 2022 Share Posted April 10, 2022 Hi, I have an interior wall with a transom window. In 3D view the wall appears to extend up to the vaulted ceiling correctly. In framing view the wall stops midway up the window instead of showing framing up to the ceiling. It is a bathroom that for awhile I had checked "Flat Ceiling Over This Room" (intended for the interior bathroom ceiling only) but unchecked it to try and show framing up to ceiling which isn't working. David Premier x13 Mac Link to comment Share on other sites More sharing options...
Doug_N Posted April 10, 2022 Share Posted April 10, 2022 Hi David, I would suggest posting the plan file. It is difficult to diagnose the problem without seeing how you have the room and framing details set up. Link to comment Share on other sites More sharing options...
DavidInMaine Posted April 10, 2022 Author Share Posted April 10, 2022 On 4/10/2022 at 7:15 PM, solver said: Do you have Auto Rebuild wall framing on, or have you rebuilt framing for that wall? Have you tried selecting Balloon Through Ceiling Above? Expand Balloon Through Ceiling Above did not work (a section of framing extended down into the window). But turning on Auto Rebuild Wall Framing with help from this link did the trick: https://www.chiefarchitect.com/support/article/KB-00335/troubleshooting-wall-framing-issues.html Thanks for your prompt replies. Link to comment Share on other sites More sharing options...
