inArtifex Posted April 5, 2022 Share Posted April 5, 2022 I just got a new computer and downloaded x13. When I open multiple views, it shows blanks. For instance, if I'm in 2D and then cut an elevation and also open camera view, when I toggle back to the 2D elevation, it's blank? Trying to figure out if this is a setting or something else? Any help is appreciated! Link to comment Share on other sites More sharing options...
TimPalmer Posted April 5, 2022 Share Posted April 5, 2022 On 4/5/2022 at 4:07 PM, inArtifex said: I just got a new computer and downloaded x13. When I open multiple views, it shows blanks. For instance, if I'm in 2D and then cut an elevation and also open camera view, when I toggle back to the 2D elevation, it's blank? Trying to figure out if this is a setting or something else? Any help is appreciated! Expand I have seen the same thing on my end. It started with the latest update for me. It's hit or miss with 2 elevations, but definitely a problem when more. If I run into the problem, I close an elevation at a time and toggle to the elevation I am needing until it shows up again. Anyone else in the same boat? Link to comment Share on other sites More sharing options...
BrianBeck Posted April 6, 2022 Share Posted April 6, 2022 This problem is not related to the recent Chief update. We have tracked this issue down to an Optional Windows update labeled KB5011543. You can uninstall this update and the problem will go away. To uninstall the update: In Start Menu, type "Control Panel" then press Enter In the Control Panel: Click on Programs Then Click on View Installed Updates Scroll down to the Microsoft Windows Section Find the update that says KB5011543(It will likely be at the top) Select it Click the Uninstall Update bottom at the top of the page 1 2 Link to comment Share on other sites More sharing options...
TimPalmer Posted April 7, 2022 Share Posted April 7, 2022 Thank you Brian for your post. Link to comment Share on other sites More sharing options...
