tbattistessa Posted March 24, 2022 Share Posted March 24, 2022 Hi All! I'm new to Chief Architect and for the life of me cannot figure out how I get casing around my pass-through door opening. I started with putting a door opening in and then a window pass through. But now I want casing around the entire opening and cannot figure out how to do that. If I turn casings back on, then it puts the casing on them separately. If I try a polyline solid 3D molding, my molding jumps to the far back slider and I cannot move it into the correct location. Any suggestions? Thank you! Link to comment Share on other sites More sharing options...
JacobB Posted March 24, 2022 Share Posted March 24, 2022 What you want is the two windows/doors to mull together. This can be accomplished in two ways: Door and windows that are close together and have the same bottom elevation will automatically mull. You can also select multiple doors and windows and manually mull them. See this link for more information: https://www.chiefarchitect.com/support/article/KB-00525/creating-a-mulled-window-and-door-unit.html. It is often hard to know exactly what is wrong from an image. It is helpful when you post a simplified version of the plan along with an image. Specifically, along with the casing not joining, the room molding is cut too short. I tried to figure out why, but I wasn't able to reproduce the issue. Also FYI 1 Link to comment Share on other sites More sharing options...
tbattistessa Posted March 24, 2022 Author Share Posted March 24, 2022 @jacobb It will not allow me to mull them?? Link to comment Share on other sites More sharing options...
rgardner Posted March 24, 2022 Share Posted March 24, 2022 3 hours ago, tbattistessa said: Hi All! I'm new to Chief Architect and for the life of me cannot figure out how I get casing around my pass-through door opening. I started with putting a door opening in and then a window pass through. But now I want casing around the entire opening and cannot figure out how to do that. If I turn casings back on, then it puts the casing on them separately. If I try a polyline solid 3D molding, my molding jumps to the far back slider and I cannot move it into the correct location. Any suggestions? Thank you! 1 hour ago, JacobB said: What you want is the two windows/doors to mull together. This can be accomplished in two ways: Door and windows that are close together and have the same bottom elevation will automatically mull. You can also select multiple doors and windows and manually mull them. See this link for more information: https://www.chiefarchitect.com/support/article/KB-00525/creating-a-mulled-window-and-door-unit.html. It is often hard to know exactly what is wrong from an image. It is helpful when you post a simplified version of the plan along with an image. Specifically, along with the casing not joining, the room molding is cut too short. I tried to figure out why, but I wasn't able to reproduce the issue. Also FYI The only problem that usually occurs with this situation (here is a doorway mulled with a pass through) is that the sill cuts into the finished floor. There are some ways to fix this including using solids, floor material regions, etc. Link to comment Share on other sites More sharing options...
rgardner Posted March 24, 2022 Share Posted March 24, 2022 1 minute ago, tbattistessa said: @jacobb It will not allow me to mull them?? They are too close together or overlapping. pull them away from each other then bump them together either with the mouse or arrow keys. Link to comment Share on other sites More sharing options...
rgardner Posted March 24, 2022 Share Posted March 24, 2022 3 minutes ago, rgardner said: The only problem that usually occurs with this situation (here is a doorway mulled with a pass through) is that the sill cuts into the finished floor. There are some ways to fix this including using solids, floor material regions, etc. Using a floor material region set to cut existing finish layer set to same material and extended through rooms. Link to comment Share on other sites More sharing options...
tbattistessa Posted March 24, 2022 Author Share Posted March 24, 2022 Yes!!!! It worked! Thank you both for your help!!!! Link to comment Share on other sites More sharing options...
