Blurry Toolbar Icons
BethVanDeusen
Go to solution Solved by Doug_Park,
  • Solution
I assume you are running with your system set to a higher DPI. For some systems, such as those that are in excess of 200 DPI the icons were so small that they were nearly unusable. We are now correctly scaling these up, although our graphics for the icons are not high resolution so they will look blurry.
You can turn this off by unchecking the "Scale Toolbar Icons for High DPI" in Preferences>Appearance. After you do this your icons will be smaller.
