Missing Living Space Totals
MHDrafting
Some additional possibilities:
  • Text Style for that layer is too small or otherwise invisible
  • Another object is in front of the Room Label and is consequently obscuring it from being seen
  • It may have been moved to a location where you can't find it - out in neverland ;).
You can try to use the "All Layers Off" Layerset and just turn on the "Rooms" & "Room Labels" layers.  Then do an F6 and marquee select the entire plan to see where it might be.
  • 1 month later...
