HStone Posted January 31, 2022 Share Posted January 31, 2022 Hi; I can't remember this ever happening before. I draw an addition off the ground level of an existing one story building and when I try to add an upper floor to it, CA adds a floor to the old building as well. Is there a setting issue? Henry Stone Link to comment Share on other sites More sharing options...
rgardner Posted January 31, 2022 Share Posted January 31, 2022 On 1/31/2022 at 1:55 PM, HStone said: Hi; I can't remember this ever happening before. I draw an addition off the ground level of an existing one story building and when I try to add an upper floor to it, CA adds a floor to the old building as well. Is there a setting issue? Henry Stone Expand I would recommend you look closer at the two options that pop up when you select add a floor. Link to comment Share on other sites More sharing options...
HStone Posted January 31, 2022 Author Share Posted January 31, 2022 I see 11 different options (I use X-13 on a PC). Link to comment Share on other sites More sharing options...
HStone Posted January 31, 2022 Author Share Posted January 31, 2022 You must mean options once I choose "Build New Floor". What should I be looking for? Thanks for your help. Link to comment Share on other sites More sharing options...
HStone Posted January 31, 2022 Author Share Posted January 31, 2022 Thanks! Too simple for me, I guess. BTW, I can't seem to get the Program to accept the jpg of my signature. Henry Link to comment Share on other sites More sharing options...
