MISSING WALL LAYERS IN FULL PERSPECTIVE OVERVIEW
ArnoldBayer
Thank you Eric, for having a look at this issue. I have done 21 house plans in the year I have been doing this and this is the only plan that I have had this problem. I watched your video and double checked which camera layer set I was using and I am using the 3D camera view set. The odd time the view comes up right and the second i try to select a wall or other detail while in the view, the siding disappears and other interior details are gone as well. I have checked all my default settings, everything seems to be as it should be. I have also compared this plan to other plans and the settings are the same.??? Thank you again.
1 minute ago, ArnoldBayer said:
Is there something I should do to end this thread?
Best thing you can do is to report back to the thread the solution of the issue once chief has helped you figure it out.  Especially if it ends up being a hardware issue or driver issue.  Someone else may have the same issue and searching and finding your solution will help others this way.
