ChiefUserWT Posted December 31, 2021 Share Posted December 31, 2021 Hello, I am new to Chief Architect and using Premier X13. I am wondering what steps I need to follow in order for a Wall Oven model that I import to show up INSIDE the cabinet when viewing with a camera? I can import the symbol, and it shows up inside the cabinet on the Plan, but not in the camera view. Here are my importing and configuration steps: Import .dwg by following these instructions: https://www.chiefarchitect.com/support/article/KB-00117/locating-and-importing-3d-symbols.html In the Symbol Specifications, under Options I specify Special Placement > Inserts Into Cabinet Front In the Symbol Specifications, under Options I specify Options > Type: Appliances (built-in base cabs) The dimensions of the wall oven model/symbol are (WxDxH) 29 3/4" x 23 1/2" x 27 5/16". The dimensions of the cabinet are (WxDxH) 30" x 24" x 36". Is there something I am missing? Thank you in advance! Link to comment Share on other sites More sharing options...
MarkMc Posted January 1, 2022 Share Posted January 1, 2022 17 hours ago, ChiefUserWT said: I can import the symbol, and it shows up inside the cabinet on the Plan, but not in the camera view. Opens this Then click Help or press F1 (you could also do that at the first DBX and then follow links if needed) Link to comment Share on other sites More sharing options...
