K80Guy Posted December 29, 2014 Share Posted December 29, 2014 Does anyone have a door like this in their library for easy placement into a print? Thanks for the help. Link to comment Share on other sites More sharing options...
AndyGump Posted December 29, 2014 Share Posted December 29, 2014 That is a Sketchup door as you know so depending on which version of Chief that you have you can place it directly into Chief. Andy. Link to comment Share on other sites More sharing options...
K80Guy Posted December 29, 2014 Author Share Posted December 29, 2014 Thanks Andy, I originally imported it incorrectly. Thanks for giving the nudge to try again. Cory Link to comment Share on other sites More sharing options...
GeneDavis Posted December 29, 2014 Share Posted December 29, 2014 The pic of the SU model is showing some kind of surround. A thin frame. The model should be edited in SU to remove the surround and just leave the door slab. Then it will model correctly when brought into Chief. Link to comment Share on other sites More sharing options...
