DOUBLE WINDER STAIRCASE/ALIGNING STAIRS ACROSS FLOORS
dbarbee
I am using Chief Architect Premier x12 interiors and need suggestions on how to create a double winder staircase. I am drawing a 5 story townhouse. The stairs I want to align across floors. I have been struggling with how to do this. However, one thing I cannot figure out how to do is the double winder staircase. Need advice.
Thanks!
I'd suggest using landings, starting on the left side of your staircase. Once you've drawn them out they can be copied and reflected to the opposite side of the stairwell. A bit of math and planning before you start with the actual landings will ensure that you don't need to make any adjustments.
I find using landings (instead of actual winder stairs) is a bit easier for dimensional control to ensure code compliance, which varies significantly from one jurisdiction to another.
