Building Bump-outs for dormers
MGM_Home
Hello Everyone,
Trying to created a "dormer bump-outs" with no luck. I have 2nd. floor with roof starting at 5 feet and then continuing on to 8 ' at 12/12 pitch. When I bump out the 2nd. floor portion of the wall for the window, the wall is going to its full height, as it should , then I place the window in the bump out that is is higher than the existing roof plane. I created a manual roof planes on the top of the bump out, but then I can't close little space between the new "dormer" roof planes and  the lower main roof plane. In essence, I want a knew wall from the new small roof place to the main - existing lower roof plane....See attached a picture of examples...Any ideas how to solve this....?
Hello Joey - thank you so much for your tip, it helped me to fix these little gaps. Any ideas how I could carry the roof planes  from the bump out without protruding into the room...? Please see the picture attached.
Thanks so much - Michael
