Steve_Nyhof Posted November 1, 2021 Share Posted November 1, 2021 Is there a place where I can set the hatch patterns as default in the dropdown? I do use a few in there but most I do not and always need to go find the one I want. Would be nice to fill this dropdown with the patterns I use. Thank you, Steve Link to comment Share on other sites More sharing options...
Kbird1 Posted November 2, 2021 Share Posted November 2, 2021 No , at least not that I am aware of , we had to ask nicely to get that list back a couple of versions ago when they moved all the Patterns to the Library. You can still import Patterns , for example from AutoCAD through the Import Dialog too if needed. M. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 6 hours ago, Kbird1 said: No , at least not that I am aware of , we had to ask nicely to get that list back a couple of versions ago when they moved all the Patterns to the Library. You can still import Patterns , for example from AutoCAD through the Import Dialog too if needed. M. Yes, I did see I can import from AutoCAD which is fine, so I guess I will add that to the suggestions. Thank you Link to comment Share on other sites More sharing options...
