How to add drywall to part of an exterior wall?
sunshine71
Go to solution Solved by scottharris,
  • Solution
The ‘lower wall type if split by butting roof’ tool you mention is available in Home Designer Pro and Chief Architect Premier/Interiors.  For your work around, you might try a section view, use the backsplash tool, reshape, and paint it.
