CVD_018 Posted October 13, 2021 Share Posted October 13, 2021 Hi - I'm using CA Home Designer Pro 2021 ... and trying to adjust the Layout page size (via Drawing Sheet Set up). Once I set the paper size to the one I want, I can't seem to find the "Page - 0" to size everything down per the tutorial and videos that I'm referencing. Any thoughts? I assumed (per video) it would be located directly under the Library Browser - but it's not there! Link to comment Share on other sites More sharing options...
SH_Canada Posted October 13, 2021 Share Posted October 13, 2021 this forum is for CA Premier. There is a different forum for HD Pro Forums - HomeTalk Forum (chiefarchitect.com) Link to comment Share on other sites More sharing options...
CVD_018 Posted October 13, 2021 Author Share Posted October 13, 2021 My apologies - thanks for the redirect. Link to comment Share on other sites More sharing options...
Dermot Posted October 13, 2021 Share Posted October 13, 2021 Basically, that information does not really apply to HD Pro. HD Pro does not have the project browser and it does not have template pages for layouts. If you want to change the drawing sheet size in HD Pro, you will need manually select and modify all of the cad that represents the page borders and title blocks. The users on the Hometalk forum may have some good tips and tricks for how to speed up this process though. The users of this forum are probably more likely to suggest you upgrade to Premier based on its more powerful tools that can make things like this easier. Link to comment Share on other sites More sharing options...
