kaitadams13 Posted September 28, 2021 Share Posted September 28, 2021 Is anyone able to help me with filling in and connecting these cabinets? I was able to do it in the upper part of the photo automatically, but I can't figure out how to do it in the lower part. I'm using Chief Architect Premier X13. Thanks Link to comment Share on other sites More sharing options...
rgardner Posted September 28, 2021 Share Posted September 28, 2021 If you want it to auto connect as in the left upper example then you need the rear points of the boxes to line up. If you are wanting a blank corner from your b15 over to your b24 then you will need to use a base filler or a customized base cabinet. Link to comment Share on other sites More sharing options...
rgardner Posted September 28, 2021 Share Posted September 28, 2021 8 minutes ago, kaitadams13 said: I'm using Chief Architect Premier X13 We appreciate if you are able to update your signature as well. Link to comment Share on other sites More sharing options...
