wall corners
winterdd
Go to solution Solved by rlackore,
15 minutes ago, rlackore said:
Select the pony wall, change the Display in Plan View setting to show the bottom wall, then use the Edit Wall Layer Intersection tool to correct the issue. Should work, but it can be tricky.
Dude, that was awesome. Learned something new.
