Bella21 Posted September 15, 2021 Share Posted September 15, 2021 Hi there. I am very green to this program. I am trying to draw a loft on a second story building with different heights of walls and a shed roof. I can make a shed roof, I can expose the ceiling, I can change the default heights for the room, but I do not know how to make different wall heights to create a half story or loft. This is for a tiny home, and the wall heights need to be 8' on the high end and 4' on the short end. Thank you in advance for helping me. Link to comment Share on other sites More sharing options...
Solution glennw Posted September 15, 2021 Solution Share Posted September 15, 2021 It sounds like you have already done it. Keep in mind that you don't set wall heights - walls build up to the roof. All you need to do is set your ceiling height to 4' and then set the roof pitch so that the ceiling height at the high end is 8' - you could do it by math, cad detail, or trial and error. The roof will pitch off the 4' ceiling height (approx) - you ay need to fine tune. 1 Link to comment Share on other sites More sharing options...
Bella21 Posted September 15, 2021 Author Share Posted September 15, 2021 Thank you, The roof pitch will be a 3/12. I'll get back with you when I figure it out. Link to comment Share on other sites More sharing options...
Bella21 Posted September 15, 2021 Author Share Posted September 15, 2021 You rock, Glenn. Worked like a charm. I appreciate your time. Link to comment Share on other sites More sharing options...
