DB-Designs Posted August 31, 2021 Share Posted August 31, 2021 Hello All, I know this subject has been discussed but has CA Premier X13 improved the control of deck columns so the bases do not overhang the edge? For a concrete porch, it's easier to fix or show properly with drawing an additional slab. Just wasn't too sure best way to do it with a deck. I thought about doing the deck with no railings then manually adding the columns and beam but I'm not sure how to do the railing so it doesn't define the room. Any thoughts? Thanks for the help in advance. Link to comment Share on other sites More sharing options...
rgardner Posted August 31, 2021 Share Posted August 31, 2021 This has indeed been considered at length. A recent search will show this gets discussed usually weekly including in x13. The general consensus is to make your railing wall wider without changing your railing size. So if you want to offset your 4" wide railing by 2" you would make your railing wall 8" wide and your top and bottom rail would be 4"... Link to comment Share on other sites More sharing options...
DB-Designs Posted August 31, 2021 Author Share Posted August 31, 2021 Thank you Ryan. I really appreciate the help! That worked perfectly for what I was looking for. Link to comment Share on other sites More sharing options...
