WHY wont you Curve? Celling. AHHHHHH?
divreig
A few ways to fix your problem, but I'll give you a couple hints.  First off, both your roof and your ceiling are set to Use Room Ceiling Finish (Structure tab).  The Room Ceiling Finish is only applied to the first roof or ceiling with that setting checked that Chief finds on its way up.  Either uncheck the setting(s) or edit the roof/ceiling plane so that the ceiling plane is lower than the roof plane.
