Sloped Railing
ProfessorChaos
See attached.
I have created winding stairs (each angle step is a landing) and I would like to have the railing run on the angle with the treads rather than how it is shown.
As far as I know there is no setting within the dialogue box for the landings that can make this happen.
Any tips? Perhaps there's a better way to create these steps than the landing method?
X3
Chaos
Thanks!
What you would need to do is to make a 3D molding poly-line as a path along which your molding profile then extrudes along. I am not saying this is necessarily "easy" but does let you define, exactly the path and appearence of the resulting custom hand rail. 3D molding poly lines can be edited in both camera and plan views to adjust the custom object to exactly what you might need and want.
