Wall Niche Symbol
Joe_Carrick
Here's a simple wall niche symbol. It inserts automatically into a wall and can be resized, moved up,down,sideways and otherwise edited. If it's in the wrong side of the wall it can be rotated 180 degrees using the symbol dbx and likewise can be moved relative to the face of the wall by adjusting the "y" origin. You might need to use a PSolid to fill the opening in the back of the wall, depending on your needs. Similar symbols can be created with different geometry such as arched, etc. Enjoy.
Wall Niche - Rectangular.calibzFetching info...
