How to build an accent roof
DMG_CLE
Go to solution Solved by Kbird1,
As a new user, I'm struggling with how to build a rooflet for a client.  Their exterior door is recessed from the front wall of the house and has very little overhang above it, so they want to add a rooflet similar to the photo below.  I can model the exterior, but cannot determine how to draw the rooflet.  I'll eventually need to use the model to generate detailed drawings for permits, etc., so I'd like more than just a visual mockup.  Any help would be appreciated.
  • Solution
Try 3 invisible Walls which should give you a room , set ceiling height as needed then draw roof planes over the 3 Walls
Mick.
