nematode Posted March 18, 2021 Share Posted March 18, 2021 It would be very helpful if I could display and configure the layout of 4x8 sheets of underlay to minimize seams in high traffic areas. I can't find this function in defaults under Framing or Floors and I couldn't find an answer in the Reference Manual either. Is this possible? If so, how is it done? Thanks in advance. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 18, 2021 Share Posted March 18, 2021 Not too difficult to do that manually with some type of polyline and multi copy tool but nothing that I am aware of to do it auto unless you use a flooring material and adjust the offset the way you want it but if you do it manually you can label the sheets and display the cut sizes as well. Just depends on how far you want to take it. It gets a little more complicated to do it for roof sheathing. Link to comment Share on other sites More sharing options...
nematode Posted March 18, 2021 Author Share Posted March 18, 2021 Chopsaw, not the answer I was hoping for but thanks for replying. Link to comment Share on other sites More sharing options...
