Hi, we have a split level home with 2 (meaning double) 2 x 4 exterior walls with a 3.5” air gap in between them for a total (rough) wall thickness of 10.5”. The home has 3 separate roof heights, all with a 5:12 pitch. The home is in central Minnesota (the reason behind the thick walls). I’m just getting started with Home Designer Pro and not sure how to start. I’ve watched some videos, but nothing that would help duplicate our wall design. Do you have some training materials that would help, or someone who could get it started on the software? Thanks for any help you can provide.
    29332
    Juliemccoy
    Juliemccoy
  • Similar Content
    • By DJohnsonSC
      I am trying to create a story and a half main house that has a two story gable roof addition.  I have been able to create the story and a half with a 1 story addition but can't figure out how to add a second story to the addition.  The main part of the house has a 10/12 roof (created by build roof options: move roof up 12', ignore 2nd floor).  The goal is to have the main roof 10/12 and the 2 story addition a 6/12 gable.
      Pics below are a quick mockup. One showing the successful story and a half w addition.  The other a bit more unusual configuration that I may not be able to get past the building inspector.
      Thanks in advance for any help provided.
    • By intendo
      The red arrows point to the problem area.
      The outside wall and interior wall at the closet intersect with the valley where the two roof planes intersect.
      The interior of the room creates an attic wall (with exterior siding) above the closet (NOTE: Ceiling was removed to get image)
      The plan view shows where the roof planes intersect at the valley. I have the same problem on the other side of the house because it is symmetrical.
      The plan is too large (65MB) but here is the model (https://3d-viewer.chiefarchitect.com/go?share=543146417714334).
      Any suggestion on how to fix this would be greatly appreciated.
    • By ChiefWhataChuck
      Civil engineer asked for roof plan. Currently. I have been able to display roof plains by floor level with slope markers. However, being it is a two level home...how do I display a complete roof for a layout plan? Along with dimensions for roof rain displacement calculation?
    • By JamesKCI
      Hey all,
      Sorry for the slight tongue-twister of a title. I'm here with another novice question.
      When creating roof plans to send to layout, I'm running into an issue. After I choose to display all of my roof planes on the same level, they appear as though the program is deliberately displaying the lower roof planes on top of those that should be above. I've attached a couple snips showing an example of how one of my roof plans is drafted and another two with what that plan looks like in plan view. It's in the roof plan view but it looks the same regardless of the layer set I use.
      Much Obliged
    • By mborean
      A lot of my work involves trussed roofs.  After building the trusses, I frame the roof for the facia and varge rafters.  Problem with this is that CA adds ridge boards that don't exist in trussed roofs.  There doesn't seem to be a way to frame without ridge boards or to set the ridge board dimensions at 0.  If there is a work around, I'd love to hear it.
      Also....  Is there a way to frame a roof where one roof California or over frames over another roof.  In my previous CAD, I could trim the bottom of one roof to the top of another and the framing acted accordingly.  This program even added a valley plate on top of the lower roof and below the rafters of the upper roof.  That may be too much to ask for, but one can only  hope.
      Love to hear what y'all have to say.
      Thanks in advance.
